Suggestion / Proposal / tip-off : SS3 !!
Moderators: simonB, nick, florent, RichterMC, Ben
deltaconcept
Post by deltaconcept » Tue Jan 30, 2018 8:27 pm
Google Translate UK :
Your user reviews !!!
What would be the most useful solutions,
most suitable for Sunlite Suite "3" ???
(Not in previous versions ...)
> Notice:
- Direct group management without using the Rec button
- Obligation to select his machines for sending an order.
- A new page at the time of the patch:
For color management in the master with a programming
group at this time all for created a true color management
in the master a can like the color page in GrandMA
A just addition for the kiff on a trichromatic when we choose a color
it displays the closest color on machines with wheels
with course on a trichro on the led at the same time.
- Better management of multi-screen.
- The possibility of having several master page
- An improvement of the pallet systems so that these last ones
are stable and effective
(UV / A color management missing, for example)
- The return of the multi page for the same range of addressable activatable on the fly (as in SL 1)
- Palette window (for use in programming + live)
- That the soft allows to keep the parameters of the pallets even between different show (to keep the presets of the machines which were to patch one day)
- Easytime as well as easystep can operate at 100th of a second freely (not of 0,04 s)
- Relative / absolute positioning for effects
- Relative positioning between machine
- Like Valentin, machine / group selection system more efficient with a program ...? emoticon smile =)
- SSL profiles in readable format (XML type)
- A 3d visualizer with interconnection with sunlite (positioning definition via recoverable 3d in Sunlite)
- A nicer 3D visualizer
- Timecode in cycles as efficient as in easyshow
- Integrate the color profile of color wheels directly
in SSL.
- When creating page, be able to determine how you can
already do it for pre-programmed movements what one wishes to have displayed. Some machine functions do not necessarily serve
it adds a useless element that we must hide in a layer
eg. to hide it.
- The ability to change the fixture of one page by another and keep
(to the extent of the possibilities of the new fixture) the encoding already carried out.
- Better management of pallets, not sufficiently exploited on SS2
and too buggy: eg can use them on any type of attributes (colors, gobos, P / T, Dimmer, ...) and define them without passing
by a specific publisher.
- Allow the recording of the effect curves in Easy Time.
- To be able to display the Easy Time editor on another screen than the one
where Sunlite is displayed.
- Better management of groups without passing a button Rec
(even if with the usual, this is less troublesome ...).
It is also possible to store the parameters assigned via the groups more easily in a button.
- Enlarge the window for saving parameters to be able to
use it in a tactile way and generally
a better tactile use of Sunlite.
Can manage the tempo directly in easyShow
by assigning it to cue in a show.
Have keyboard shortcuts for some setup functions
(switch parameter for example, page parameter, etc).
support for other colors (amber, UV) associated with the wheel
RGBW color.
the integration of a global color wheel on the Master page.
The ability to record a pre-established config for a midi controller
and export / import it on other shows such as pre-config BCF2000 and midicon (globally when you rarely use the same show twice,
it's a bit heavy to redo some manipulation with each encoding)
In easyshow make the points of the curves dimmer time line more practical (very painful to catch them with the mouse even with 2 screens 24 inches) and also to zoom on the y axis of the time line.
To be able to reorganize the order of the tracks of time Linesans
be imposed the alphabetical order.
FRANCE :
Vos avis d'utilisateurs !!!
Quelle serait les solutions les plus utiles,
les plus adaptés pour Sunlite Suite "3" ???
(Absente des versions précédentes...)
> Avis :
- Gestion de groupes directe sans passer par le bouton Rec
- Obligation de sélectionné ses machines pour envoyé une commande.
- Une nouvelle page au moment du patch :
Pour la gestion des couleur dans le master avec une programmation
de groupe a ce moment le tous pour créé une vrais gestion des couleur
dans le master un peut comme la page couleur dans GrandMA
Un rajout juste pour le kiff sur une trichromie quand on choisi une couleur
il affiche la couleur la plus proche sur les machine avec des roues
avec biensur une trichro sur les led en même temps.
- Une meilleure gestion du multi-screen .
- La possibilité d'avoir plusieurs page master
- Une amélioration des systèmes de palettes pour que ces dernières
soient stables et efficaces
(gestion des couleur UV/A manquant par exemple)
- Le retour du multi page pour une même plage d'adresse activable désactivable à la volée (comme dans SL 1)
- Fenêtre palette (pour utilisation en programmation + live)
- Que le soft permette de garder la paramètres des palettes même entre différents show (garder les présets des machine qui fussent patcher un jour)
- Easytime ainsi que easystep puisse fonctionner au centième de seconde librement (pas de 0,04 s)
- Positionnement relatif/absolu pour les effets
- Positionnement relatif entre machine
- Comme Valentin, système de sélection de machine/groupe plus efficace avec un programmer... ? émoticône smile=)
- Des profils SSL au format lisible (type XML)
- Un visualiseur 3d avec interconnection avec sunlite (définition de positionnement via la 3d récupérable dans Sunlite)
- Un visualiseur 3d plus jolie
- Un timecode dans les cycles aussi efficace que dans easyshow
- Intégrer le profil colorimétrique des roues de couleurs directement
dans les SSL.
- Lors de la création de page, pouvoir déterminer comme on peut
déjà le faire pour les mouvements pré-programmés ce que l'on souhaite avoir d'affiché. Certaines fonctions de machines ne servent pas forcément don
ça ajoute un élément inutile que l'on doit masquer dans un layer
par ex. pour le cacher.
- La possibilité de changer la fixture d'une page par une autre et conserver
(dans la mesure des possibilités de la nouvelle fixture) l'encodage déjà effectué.
- Un meilleure gestion des palettes, pas suffisamment exploité sur SS2
et trop bugguée : par ex. pouvoir les utiliser sur tout type d'attributs (couleurs,gobos,P/T, Dimmer,...) et les définir sans passer
par un éditeur spécifique.
- Permettre l'enregistrement des courbes d'effets dans Easy Time.
- Pouvoir afficher l'éditeur Easy Time sur un autre écran que celui
où est affiché Sunlite.
- Une meilleure gestion des groupes sans passage par un bouton Rec
(même si avec l'habitude, cela est moins gênant...).
Pouvoir également storer plus facilement dans un bouton les paramètres affectés via les groupes.
- Agrandir la fenêtre d'enregistrement des paramètres pour pouvoir
l'exploiter de manière tactile et de rendre de manière générale
une meilleure utilisation tactile de Sunlite.
Pouvoir gérer directement le tempo dans easyShow
en l'affectant à des cue dans un show.
Avoir des raccourcis clavier pour certaines fonctions de paramétrage
(paramètre de switch par exemple, paramètre de page, etc).
la prise en charge des couleurs autres ( ambre, UV) associé à la roue
de couleur RGBW.
l'intégration à la page Master d'une roue de couleur globale.
La possibilité d'enregistrer une config pré-établie pour un controleur midi
et l'exporter/importer sur autre show comme les pré config BCF2000 et midicon (globalement quand on utilise rarement deux fois le même show,
c'et un peu lourd de refaire certaines manip à chaque encodage)
Dans easyshow rendre plus pratique les points des courbes dimmer des time Line ( très pénible de les choper à la souris même avec 2 ecrans 24 pouces) et aussi permettre un zoom sur l'axe y du time Line.
Pouvoir réorganiser l'ordre des pistes du time Linesans
se voir imposer l'ordre alphabétique.
Re: Suggestion / Proposal / tip-off : SS3 !!
Post by nick » Wed Feb 21, 2018 4:44 pm
Thank you for these suggestions.
They have been submitted to the project manager in charge of Sunlite Suite 3 for consideration and you should have received a response via email.
