High resolution displays (4K...)
Moderators: simonB, nick, florent, RichterMC, Ben
sbehnsen
Post by sbehnsen » Tue Dec 19, 2017 7:07 pm
I noticed that SS3 (and also the previous versions...) do not Support High Resolution Displays (e.g. 4K) very well.
Everything is so small that it is not usable...
Since 4K displays are getting more common I believe supporting them correctly is a must for any new software.
As a workaround I tried using an external manifest file (Setting DPI aware to "false") but this did not work for me with Suite3.exe.
Re: High resolution displays (4K...)
Post by nick » Wed Dec 20, 2017 4:28 pm
We are aware of the problem of Sunlite Suite 2 and 3 running on very high resolution displays. I have added this to our list of problems to look into.
sbehnsen
Post by sbehnsen » Fri Dec 22, 2017 2:27 pm
Thanks,
This is currently one of the most pressing issues for me, because I can not use my new Laptop and have to use an old one just for sunlite...
Post by nick » Fri Dec 22, 2017 4:36 pm
Hi sbehnsen,
It is possible to use it on a high resolution display simply by dropping the display resolution to something lower. You will also need to adjust the font scaling to 100% on the Display window in Windows. Anything above this will cause problems with the interface.
sbehnsen
Post by sbehnsen » Mon Apr 09, 2018 11:27 am
Dropping the Display Resolution is not really a solution... Yes it may work for a test, but no more.
Adding Support for this should not be an issue, and since more and more machines move to 4K or other high Resolution Displays, this is something I think you can not simply ignore.
By now pretty much all software vendors have added support für high Resolution Displays in their Software.
Post by nick » Wed Jun 20, 2018 7:59 am
Thank you for your feedback. I have passed it onto the project manager responsible for Suite3. We are concerned that to support Windows font scaling might delay the Suite3 project beyond a reasonable amount of time. We realize the inconvenience of having to change display resolutions and we will be looking at supporting it in future projects.
