Wrong Calculation of DMX Values in EasyTime
Moderators: simonB, nick, florent, RichterMC, Ben
DATechnics
Post by DATechnics » Tue Nov 21, 2017 12:15 pm
Dear Nicolaudie-Team,
if I create movements with EasyTime and slow down the speed, the movement is not smooth due to not calculated intermediate values.
For example: A TILT-Movement with 16-bit fixtures with very slow speed:
1st value:
Channel 1 (Y) : 193
Channel 2 (mY): 249
next value:
Channel 1 (Y) : 195
Channel 2 (mY): 131
This results in a stepwise movement of the heads.
If the movement should be smooth, you have to increase the mY Value from 0 to 255, then Y can be increased by 1 (at the same time, mY has to be set from 255 to 0).
This has always been a problem in Suite2, but not in Suite1.
Would be very nice, if you fix this with the release of Suite3.
Best regards
Alex
Re: Wrong Calculation of DMX Values in EasyTime
Post by nick » Tue Jan 23, 2018 3:13 pm
Hi Alex,
I have just received an update that the 'Problem with micro pan/tilt when limiting the area' causing jerky movement has been fixed in Sunlite 2 and 3.
viewtopic.php?f=45&t=41049
It could be this is the same problem you experienced here. Once I have a new build to test I will see if this is the case.
Post by nick » Tue Jun 19, 2018 11:16 am
Hi Alex,
This problem has been fixed in the latest beta of Sunlite Suite 3.
https://storage.googleapis.com/nicolaud ... e3Beta.exe
It has also been fixed in Sunlite Suite 2 beta.
