Multiple universes
Pavlov
Multiple universes
Post by Pavlov » Tue Feb 19, 2019 6:30 am
Hello!
How many STICK`s can I connect together? How many universes can I get?
Do you have manual for that?
Thanks!
Re: Multiple universes
Post by nick » Mon Mar 11, 2019 4:00 pm
Hi Pavlov,
It's not possible to output more than 2 DMX universes (1024 channels) from a STICK controller running in Standalone mode. While it's possible to sychronise more than 1 STICK controller over a network, this does not give you more universes. This function synchronises the areas so that each STICK plays the same scene in the same area.
It is possible to link 2 or more SLESA-UE7s together over a network to give you many universes as long as the scenes are all created in the global area and ESA Pro (v1) is used for programming. For example you could connect 10 SLESA-UE7s to give you 20 universes.
https://www.nicolaudie.com/manuals/#/en ... rk-control
