Tunable White Color Wheel
evolve1971
Post by evolve1971 » Tue Dec 18, 2018 9:35 pm
Can you assign the color wheel to scroll through white ranges on a strip with an RGB chip and two separate white chips. I'd like to be able to scroll through colors on the RGB chip and have the wheel scroll through white points via mixing the two white chips (27K and 6K). Thanks
jon
Re: Tunable White Color Wheel
Post by nick » Wed Dec 19, 2018 5:00 pm
Hi Jon,
Is this an RGB WW CW or similar?
It is possible to control the RGB and the WW / CW channels independently from the colour wheel.
For this to work ...
- The Stick-DE3 must be programmed with the correct profile for your lights. You may need to modify an existing _generic / RGB profile to add the extra colours using Scanlibrary editor (included with software).
- Once programmed with ESA2 or ESA Pro, you will need to press the colour palette icon on the Stick-DE3 to swap between the RGB and extra colours. Then use the colour palette to alter the values.
