Hardware HELP
Rummage
Hardware HELP
Post by Rummage » Fri Jun 24, 2016 9:48 pm
Hello all,
If i was to purchase a Stick DE3 is there any other hardware i will need to make it work?
Can i output dmx direct from the Stick DE3? Or do need other hardware?
Thanks and sorry for the lame question. My thinking is that i can buy a Stick DE3 for €769.00 and program it through my PC with ESA Pro Software.
IS there anything else i need to buy? Power adapter?
best
rummage
Re: Hardware HELP
Post by nick » Mon Jun 27, 2016 3:19 pm
Thank you for your question.
The STICK-DE3 comes with a power adaptor so it is not necessary to buy a separate one. The only hardware you should need are the lights themselves and cables to connect them. Some lights, such as RGBs, don't include DMX drivers built-in, so these also need to be purchased.
If you want to use 2 x DMX universes (1024 channels) you will also need to purchase an RJ2Block to connect to the Power + DMX socket on the back.
Please see the datasheet to see how to connect cables to the back of the STICK-DE3. You can download this from this page ...
https://www.nicolaudie.com/en-gb/stick-de3.htm
