Firmware 1.07
The star of the STICK family.
Firmware 1.07
A new firmware version is available online and can be downloaded here:
http://www.dmxsoft.com/global/ftp/HardwareManager.exe
http://www.dmxsoft.com/global/ftp/HardwareManager.dmg
Changelog:
-minor bug corrections and optimisations. In particular improvements to the SD card writing processes.
-remove 2gb card limitation- now 32gb
-possibility to disable auto backup of dimmer/speed/color changes. This can extend SD card life and prevent SD card corruption if power is lost whilst the modifications are being backed up
-show error on screen if there’s a fault with the clock (i.e. if the battery is missing)
-if fading is disabled on a channel scene fade times are now also ignored on the channel
-screen no longer flickers when receiving TCP/UDP commands
-problem corrected with behaviour of color wheel when used with the remote app
-show INIT SD CARD when the SD card is being initialised as the controller is being powered up (before a white screen was shown). This can help distinguish between an SD card initialisation problem and a screen problem
tpm
Re: Firmware 1.07
Post by tpm »
is this a problem of card corruption you mention?
--> Just have a situation with a probably defective SD card. The Stick DE3 doesn't start correctly anymore and the startup procedure only goes to the screen with the date and time. Connection to a PC via USB isn't possible too.
Re: Firmware 1.07
I haven't seen this corruption problem, but in this situation I would reformat the microSD card to FAT (Not FAT32) and try again. Or replace the microSD. Did you get the issue resolved?
