Wifi connnection
Posted: Thu May 14, 2015 6:33 pm
Is there a way to enter WiFi password on STICK 3 to talk to Arcolis on iPhone and ESA2 on laptop via company WiFi?
I followed the below instruction on STICK menu and didn't see place to enter WiFi password -
"Other Ethernet options can be set within the STICK-DE3's menu.
-Hold the on/off button for 5 seconds
-Use the right arrow to scroll down to 'Ethernet'
-Press the center reset button to enter
Here you can change the IP address of the controller. Enabling DHCP will allow an IP address to be assigned automatically from your router (if this is enabled in your router settings). "
Thanks a lot in advance for the help!
