procedure firmware-update
jacou
Post by jacou » Sat Dec 22, 2012 11:26 pm
The stick DE3 is super. I love the app-update !!
Since I have an early edition, i would like to update the firmware (it is still version 0.94)
The website doesn't seem to explain the procedure to do this??
1) My computer is in the same network, i can do all the operations trough ESA-pro. My computer has a network-connection with the Stick.
2) I download the latest version of the firmware
3) unzip, and run the hardwaremanager
4) ... but what is next? The hardwaremananger notices "no device connected"???
the "hardware-configuration-tool" from "menu start" doesn't connect either?
Looks like an Ethernet-connection is not enough?
Is a USB-connection needed?
Do I need to update trough the micro-SD-card?
What needs to be connected in order to make the firmware-update?
Re: procedure firmware-update
Post by simonB » Mon Dec 24, 2012 9:22 am
You need to connect the STICK to your computer with a USB cable to update the firmware
jacou
Post by jacou » Mon Dec 24, 2012 6:09 pm
yes, connecting with the usb worked out fine.
thanks.
