Loading Images on STICK DE3
Erv
Post by Erv » Sat Aug 18, 2012 4:54 am
Hi There
I have been trying to load scene images on to the DE3 but it says "Load BMP Fail".
Follows is the procedure i have assumed for this process:
  • Double click in the box for the scene under the load image coloumn
    Press the open Image button
    Select image in Open image dialog
Am I doing something wrong here?
The image size i am trying to load is 104 x 78 Pixels
What should the pixel size of the image be?
SPECS:
ESA PRO: Aug 6 2012
Windows 7 OS
STICK3 Firmware 0.92
Thanks in advance
Re: Loading Images on STICK DE3
Post by simonB » Fri Aug 31, 2012 2:40 pm
I think this is a bug in the ESAPro software. Try again in a new show and if it still doesn't work, send over the BMP you're trying to load and we'll test here.
