I would like to know if the port behind the Stick-GU2 may be connected to a sunrise detector to trigger a scene ?
I know it's possible with the other one but i don't know if the only port of the stick GU2 works the same.
Thanks,
sunrise activation port
Re: sunrise activation port
Hi there,
You can map a scene to be triggered by the port on the Stick-GU2. That scene could be programmed to play for x amount of time and then stop. How long do yo need it to play for? Do you know how the sunrise detector works in terms of closing / opening the connection?
- gu2 port functions.png (67.65 KiB) Viewed 6316 times
