Stick-KE1 Network Connection Compatibility Firmware 1.21
Post by nick » Fri Jan 05, 2018 3:57 pm
If you wish to connect your Stick-KE1 to Sunlite Suite 2 by network, please make sure you are using the following version from 27th Jan 2017 and the older 1.20 firmware ...
https://storage.googleapis.com/nicolaud ... te2_7a.exe
And, of course, add firewall exception rules for Sunlite Suite 2 or disable the firewall altogether.
Later versions which use firmware 1.21 only work via USB connection.
