Console buttons
Dojec
Console buttons
Post by Dojec »
I have another question about designing your console.
I create a console with 20 buttons for instance in the console editor.
I save it and load it in suite2 to add my controls to it.
If everything is finished I would like to add/delete some buttons in the console editor.
I save it again, but when I load the console layout in the suite2 again, then, even with keep settings, the controls I assigned to the buttons are shifted.
So it looks like if you program button 1 to 20 in the console editor, then afterwards you delete button 15 for instance, instead of having button 1 to 14 and 16 to 20, it seems to be renumbered from 1 to 19. Meaning that what you programmed for button 20 is now assigned to button 19.
This is a real pain as it takes a lot of time to assign all controls to these buttons.
Is there a sollution for this?
version:29/02/2016
mtregael
Re: Console buttons
Post by mtregael »
Hi Dojec,
There is no "id" to identify the objects of the console.
So, the order of the objects in suite2 is made by file reading order... it's a cheap method.
I have spoke about that with the developper and there is no workaround at this time.
Gael
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
