firstly I want to say hello to the community and excuse myself for my bad english! (German writing ;) )
I've got the following question or wishes to realize:
For example I use some LED pars:
I'd like to create a scene where the first, third and fifth Par flash alternately to the second, fourth and sixth.
So I got this already, now the part wich is difficult for me:
I'd like to have buttons for example to change the first group in red, green or blue and some buttons to change the color of the second group independently.
I tried some switches but, they stay activated when I chose another one and if you check that the button should deactivate the others when switched on, then it turns the button of the other group off also.
I would be very happy if someone can help me with this!
Greetings from Germany!
smokesurfer
Question: Color Change Buttons
Re: Question: Color Change Buttons
Hi smokesurfer,
Welcome to the community, you're English seems very good to me!
What you want to achieve is possible, I've created a test show for you to try. The main switch which controls alternating flashing between 1,3,5 & 2,4,6 has been set to 'SUB subtract from the current level' in the switch settings. I have then created a series of other buttons to change the colour of the 2 sets. You can also override the whole thing using the colour mixing button if you wish.
The subtract setting inverts the effect though, so if you need your fixtures in a special order you will need to program them in the opposite order in the Main Switch.
Hope that helps.
Hope that helps.
- smokesurfer.shw
- Demo Showfile
- (20.65 KiB) Downloaded 407 times
Benno
Product Support
Product Support
Hello Benno,
first I'd like to say thank you for your answer and test show!
You helped me really!
So I've found a new phenomenom while testing the Show:
I choose one color for 2,4,6 and then one for 1,3,5.
I can change the color for 1,3,5 as often as I want, but as soon as I press one other button for color 2,4,6 the color for 1,3,5 gets also resetted.
Maybe you have a little trick for that also.
Greets,
Greets,
Hello Simon,
Bens showfile is not correct. Sorry Ben!
@Simon
I left you an old and a new switch in the show file. Please have a look at them to see the fault.
A tip: Use the layer settings to customize and rearrange the software's look to your needs. I gave you a small suggestion in your showfile.
@Simon
- smokesurfer.shw
- (21.29 KiB) Downloaded 409 times
