Scaling Sunlite Suite 2 with 3D Easy View
wgroe
Post by wgroe »
I have a fixture which is able to pan and tilt.
Sunlite Suite 2 acts as following which is correct:
- Setting pan DMX=0 leads to physical pan=0 degree.
- Setting pan DMX=255 leads to physical pan=360+180 degree= 540 degree
3D Easy View simulation acts as following which is wrong:
- Setting pan DMX=0 leads to simulated pan=0 degree.
- Setting pan DMX=255 leads to simulated pan=360 degree
How can I scale 3D Easy View that it reacts in the same way than Sunlite Suite 2 ?
Kindly advise how to proceed. Thank you.
Ben
Re: Scaling Sunlite Suite 2 with 3D Easy View
Post by Ben »
Hi there,
Please can you check to see if you have the right values for Pan entered in the fixture profile settings. If you open the Scan Library Editor go to your fixture and make sure Pan angle = 540.
I have attached a screenshot that may help.
Let me know if you're still having problems
Cheers,
Ben
