Hi there,
HAPPY NEW YEAR ...
I am desperately trying to restrict sunlite to go over a certain dmx value from a certain fixture channel.
Let me try to explain it as follows:
I have a RGB Fixture with an additional master dimmer channel. This dimmer channel has 2x purposes:
- From 0-190 it controlls the master dimmer.
- From 190 - 255 it has some values with stupid effects which I do not want to be used
Now my question:
What is the easiest way to restrict sunlite to ignore all values above 190 ? I have been trying to adapt the scan library preset but I did not get it to work properly. Do you have an idea for this?
Kinds,
Oliver
Restrict value in a specific channel
http://www.jmarquardt.com/
http://rote-sonne.com
Sunlite Suite 2 FC
Sunlite STICK
Sunlite SL512EC
APC 40
BCR 2000
Sunlite Suite 2 FC
Sunlite STICK
Sunlite SL512EC
APC 40
BCR 2000
Re: Restrict value in a specific channel
You can restrict values using a dimmer min-max in a switch.
- Create a new switch in your RGB fixture page.
- affect "Dimmer Min-Max" on the extra dimmer property of each fixture.
- select the "min" box and move the slider to "0",
- unselect the "min" box and move the slider to 190.
- save the switch.
- Shift + right click the switch and activate "Show fader: Dimmer"
Now, you can move the Dimmer fader of this switch from 0% to 100% and the dmx value will be from 0 to 190.
Gael
- save the switch.
Gael
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
*** Freelance ***
