embedded in a button didn't work correctly
Moderators: simonB, nick, dylan, florent, RichterMC, Ben
Astey
Post by Astey » Fri May 10, 2013 5:05 pm
on wednesday we tried "embedded in a button" feature with the latest beta. after exiting live mode
the program was still recording, however none of the buttons showed up in the changes list. every switch got a yellow triangle. in the end it was like ss2 was unable to control. even restarting the program didn't fix it. 5 minutes later all the changes showed up in the sub-menu.
cheers
RichterMC
Re: embedded in a button didn't work correctly
Post by RichterMC » Sun May 12, 2013 8:51 pm
Can you reproduce this all the time ?
Best
Gernot
Astey
Post by Astey » Wed May 15, 2013 2:45 pm
not yet since it was a friends computer. ill try it on my own machine
Post by simonB » Mon May 20, 2013 6:23 pm
Make sure you have the correct tab selected. For example, if you click embed inside the button, then click record, then click live, you won't see the changes
