movement : different constant pan values
Fisherman
Re: movement : different constant pan values
Post by Fisherman » Sat Jan 12, 2013 2:18 pm
Hello Smilestone,
I want to combinine : tilt movement : sinus wave, differet pan constant level for each head/scanner
This is very simple:
First of all on the pan channel you have to create an easytime sinus effect to all your fixtures . The next step is closing the easytime window and replacing the easytime effects on each Pan channel with an easystep or dimmer. After doing this it should be possible to set for each fixture a different value.
Of course this is posible with the Tilt channel, too.
Hope I could help you.
Marcel
Post by simonB » Tue Jan 15, 2013 9:20 am
These are built using easytime effects. More information on this can be found here:
Fisherman
Post by Fisherman » Wed Jan 16, 2013 9:11 am
is it possible to edit the pan and tilt effects afterwards ?
I found out that if you have static pan values it isn't possible but if you have static tilt values it is.
This is also possible with pallets.
Do you mean the "center" option? This works, but there isn't the possibility to set a sinus effect. Moreover it seems there is a little bug: If you built a circle and use the center option the movers starts stuttering while moving this circle. If you don't use this function they move smooth.
In the future it would be nice if you can built a position scene and built for example a circle movement with a switch button. Then it would be possible to combinate different possitions with different movements.
At the moment you can do this with the add/sub mode at the switch priority but then the circle is over or under this position. This means we need an combinated butten.
I hope you understand what I mean.
Marcel
