i use Buttons on the Midicon Flash Section (bottom right corner) and strugel a little bit with the Feedback.
I want to achive that when a button is active in the Software the LED on the Midicon lits which works if i press the Button in the Software.
However if i press it on the Midicon the Button gets activated and stays so (ON/Off in active Level and Deaktivated for outside active Level) however the LED lits only durng i have my finger on the sensor .. any Idea ?
Regards
Holger Steppke
MIDI Feedback on MidiCon Big Flash key
Re: MIDI Feedback on MidiCon Big Flash key
I'm guessing that the midicon is automatically switching this button LED off? Does it do the same when it is not paired with any command?
Try setting the 'Feedback when control data received' option to 'True' in the Console setup. This will send an ON message back to the midicon when the button is pressed.
- Contact:
Hello...
may be this is nearly the same problem ??
http://www.nicolaudie.com/forum_support ... 32&t=36717
