Fade Time
hsteppke
Fade Time
Post by hsteppke »
it would be nice if there would be (maybe there is and i juts havnt found it) a kind of Fadetime Dial/Fader/Setting that would allow for eg Chaser Effekts to fade from one step to the next and the same for a Scene so that if i select the next scene it gets fade in and the prev scene gets fade out so that a show is a bit more smooth. Preferable it should work in a way that if its 0 all behaves as normal and if i turne it up everything fades from one step to another from one scen to another.
I missed this specificaly on a live show is used Sunlite for on one of the last weekends. We had LEDs RGB Fixtures there and Par64 so switching LED Scenes.
So i can have everything look smooth whithout changing every scne to use a fadetime.
Regards
Holger
Re: Fade Time
I'm not completely sure what you mean here. Do you mean a way to set a fade time on all scenes at once? This is possible if scenes are stacked within a Cycle.
