Feature: Audio File Analysis as Easy Time Effect
hsteppke
Post by hsteppke »
im after a possibility to have a value following an Audio File ... not from the Input .. more from a fiele that i play using a Button.
For me it would work to have an EasyTime Effect available in which i can specify the Fielename and once the Easytime gets active the file is followed.
Using eg the Volume of that file and to be perfect have some timers for Attack and Decay
Similar to what the GIF/Video Effects does
Regards
Holger
Re: Feature: Audio File Analysis as Easy Time Effect
The bargraph and bpm triggering only works from a single sound source from the Audio Analysis. We don't plan to change this for now.
We are considering the possibility to insert a wav file into EasyTime with a viewable sound wave so that you can easily program an easytime effect to the music.
