I have found the options "timed control" and "sound to light", both are working fine independently. However i would like to be able to select a scene/swith where i can swith from timed mode with speed control to "sound to light" using my elation midicon controller.
I already found the way to assign the "tap sound to light" to my midicon controller, only now i have to make seperate scenes/switches for "sound to light" and for "timed control" where i would rather have just one scene/switch.
Any help?
Switch time control to "sound to light" for one scene
Re: Switch time control to "sound to light" for one scene
Unfortunately there is no way to do this at the moment as the sound activation property is saved inside the button
Any good alternative in mind sparing me to double program every scene/switch ?simonB wrote:Unfortunately there is no way to do this at the moment as the sound activation property is saved inside the button
What about creating a new "Empty" Scene Button -> then copy in the existing Scene Button into the new Button by moving it over the Empty Scene using "Controll (Ctrl/Strg) + Right Mouse" and if you drag you get ask to copy or move.
Then go into the Button and change the Settings for Audio ?
Holger
Holger
