matrix effects on sunstrips
raystream
Post by raystream » Thu Jun 16, 2011 10:06 am
hi
i have several sunstrips (10pcs) and would like to use the matrix effect like rain or butterfly.
but after assigning the effects and activating it there is no output on the dmx site.
they behave strange in the fixture matrix (there were i can see all fixtures and arrange them like on stage)
when i dimm channel 1 all lights are dimmed all other dimmers don t show anything in this view, the dmx output is fine.
only the view is not ok.
with this strange view i can live but i need the matrix effects on them.
the have no rgb dimmers but in the matrix definition i can choose any color, perhabs this is the failure?
RayStream - Media
http://www.raystream.de
raystream
Re: matrix effects on sunstrips
Post by raystream » Thu Jun 16, 2011 11:01 am
now i tried it with 10 single dimmer fixtures for each sunstrip
but matrix effects (rain, butterfly, text,...) are failing with no output
RayStream - Media
RichterMC
Post by RichterMC » Thu Jun 16, 2011 11:33 am
if you send me your show I´ll take a look.
What I found out lately, that matrix FX from older shows don´t seem to work with the Jun 7 version.
Best Gernot
raystream
Post by raystream » Thu Jun 16, 2011 12:56 pm
thank you
but now i need your email address i can send the show file to.
RayStream - Media
Post by simonB » Fri Jun 17, 2011 11:05 am
click the username on the right, then click send e-mail
hsteppke
Post by hsteppke » Thu Jun 23, 2011 11:03 pm
hahahahahah ... i like that one :)
I had EXACTLY the same question a few days ago ..... i put 10 vertical stripes next each other as a stage background and ... was trying to make use of them.
The problem is the Stripes are basicaly (just) dimmer channels and matrix and so so do only work on RGB channels (not on intensitiy channels)
I did played around with just waves and there size/phase/speed till i had a couple of OK Buttons ...
And i here because i was looking for a new beta to lay with, maybe (you never know) those effects can do intensitiy channels as well now ...
Regards
Holger
hsteppke
[solved] Re: matrix effects on sunstrips
Post by hsteppke » Mon May 21, 2012 5:32 pm
Matrix does now also work on single Dimmer channel if there is no RGB
