After updating the firmware the interface to the latest version, it does not respond, the 7 segment displays do not turn on, the power LEDs, LED dmx 1, Led dmx 2 and Led dmx 3 emit light but do not flash. I need to know if I can put the interface in boot loader to see if I can reinstall the firmware. I can't even see the serial number. USB does not detect anything.
NECESITO AYUDA URGENTE! Adjunto un link a mi drive con fotos de la interfase y la falla.
https://drive.google.com/drive/folders/ ... sp=sharing
Siudi FC no work - the interface does not respond, the 7-segment displays do not light
- sunlite 3.jpeg (58.23 KiB) Viewed 4743 times
- sunlite 2.jpeg (104.09 KiB) Viewed 4743 times
- sunlite 1.jpeg (124.9 KiB) Viewed 4743 times
Re: Siudi FC no work - the interface does not respond, the 7-segment displays do not light
I have sent you a PM about your issue.
i have exactly same problem with 2 interfaces at the same time :-(
see below:
https://youtu.be/crFeKtvYH7E
Tomhat, can you help me too :-) pls.
Big thanks in advance :-)
see below:
Of course, let's do this.
To anyone else who's experiencing the same issue, please open a ticket about it via :
- SUNLITE : https://store.sunlitepro.com/en/support .
- Easy Stand Alone softwares : https://store.nicolaudie.com/en/support
