Trigger ports HE10 and motion sensor?
pileo
Post by pileo » Sat Jun 20, 2015 3:01 pm
I am an absolute beginner in electronics... Is it possible to use the trigger contacts (HE10) to use a motion sensor to trigger sunlite?
If yes, how to connect the motion sensor and the sunlite device?
Thanks!
Leo
pileo
Re: Trigger ports HE10 and motion sensor?
Post by pileo » Tue Jun 23, 2015 4:42 pm
Noone...? :(
Ben
Post by Ben » Wed Jun 24, 2015 10:25 am
Hi Pileo,
Yes this is definitely possible using the HE10 ports, below is a link to the relevant section of the hardware manual which has all the information you need.
http://manuals.lightingsoft.com/en/26-1 ... TE-gY7.htm
Hope that helps.
pileo
Post by pileo » Sun Jun 05, 2016 7:43 pm
Hello
The manual is not available anymore. Can you please help me?
Thank you!
peteknobloch
Post by peteknobloch » Mon Jun 06, 2016 1:27 pm
To work your motion detector MUST have relay contacts that close when motion is detected. There MUST NOT be any voltage that feeds out of the motion detector. Just a switch closure from the relay. Connect the normally open relay contacts to the GND and P1 of the HE-10 port. There was a document that talked about it but my old link doesn't work anymore. Look here for a simplified connection. https://storage.googleapis.com/nicolaud ... asheet.pdf
