Serial 0 Product Code:0
Pantelis
Post by Pantelis » Wed Oct 03, 2012 7:58 pm
Dear Friends,
I have a big problem with my SIUDI 7A inteface.
The SunliteSuite 2 did not recognizes the interface and works in Demo Mode, but the Tools.exe works fine in the Test tab.
I think the problem is that the Tools.exe in the Firmware tab writes "Serial 0 Product Code:0" !!!
What i can do about it, i am from Greece and this is Urgent!
Thank you.
Re: Serial 0 Product Code:0
Post by simonB » Thu Oct 11, 2012 4:46 pm
open the tools application, if your interface is detected here, update the firmware. If not:
-try a different computer
-try a different USB cable and USB socket
-try starting in bootloader mode:
power off your interface
create a shortcut on p2-p3-p4-GND ports
power on your interface
start tools.exe
update the firmware
remove the shortcut
start tools.exe
update the firmware again
A ball of foil can be used as a quick way to connect the ports
if it is still not being detected, send me a mail and I will arrange an RMA
