STICK Pre-purchase Question
Posted: Wed Mar 10, 2010 11:55 pm
I have a STICK DMX addressing question. My plan is to have 2 rooms setup with independent RGB LED strips, approx. 5 meters each, controlled by a single STICK.
1) Creating a shopping list, what other than the LED ribbon and the STICK itself would be needed? Assuming that the LED ribbon has no address means by itself, there seems to be additional hardware needed to achieve different colors/effects on each segment simultaneously.
2) The STICK has 2 universes available, can I plug one length into each set of ports, creating two "zones"? Is there enough power for the LEDs if that is possible?
I scoured the FAQs and other online sources and didn't see anything about this basic setup.
Thanks in advance,
Mike
Thanks in advance,
Mike
