Custom LED Screen Shape
beliy333
Post by beliy333 »
Is it possible to create a custom LED screen size? For example, I have a LED screen or LED curtain which is 8ft x 2ft. How do I create something like this in the visualizer?
Thanks!
Re: Custom LED Screen Shape
hi, you can change the dimensions of an object using the second tab of the settings panel inside construction mode
beliy333
Post by beliy333 »
But I can't make just any object an LED screen that I can control. It has to be a fixture. I know I can make custom shapes from objects but how about making a custom shape led wall? Is there a way to edit the dimension of a fixture? Like change the width of an LED bar or LED panel?
beliy333
Post by beliy333 »
Yes but are you able to change the dimension of an LED panel? I can make a custom shape but I cannot make it light up as if it was an LED panel.
