Fixture Creation Little Help Needed
Posted: Sun Mar 25, 2012 4:27 pm
Hi Guys,
Can you please help me correct 2 small issues im having with my fixture profile.
I have a moving head with 13 channels. All channels have been correctly created in the profile. Everything checks out right with the actual head and corresponds correctly except 2 channels. The GOBO SHAKE channel. The problem is that the visualizer shows the gobo shake in the wrong manner. The gobo shake channel is a fader which is from 0 - 146 which makes the gobo shake from slow to fast. But in the vizualizer the button dimmer causes it to shake from fast to slow. Inverted. The real head is working correctly, that is when i rise the dimmer the gobo starts shaking faster as it supposed to. But in the vizualizer its inverted and shows it starting out fast and slows down as i raise the dimmer slider.
The second problem is with the PAN/TILT SPEED channel. Even there the dimmer is reversed. I mean 0% means the heads pan and tilt fast and 100% means the pan and tilts are very slow.
These 2 might sound very simple but very counter intuitive when working creatvely on scene creation etc. Id greatly appreciate anyone helping here. Im sure you guys can help. Almost 5 channels had problems and i corrected them myself but its taken me 7-8 days of work on this profile to get this far just to create the fixture .ssl, instead of working creatively with this software, im spending days just ironing out the problems and creases. I cannot imagine how programming the show will be.
Regards
Regards
