Easy view 3D Sep 28
Posted: Sat Oct 15, 2011 10:20 pm
by gabrielefx
Dear Sirs,
the Movie recorder doesn't work for me.
I try to save an avi file and I get an empty video, all frames are white.
Any help?
Re: Easy view 3D Sep 28
Posted: Mon Oct 17, 2011 12:45 pm
Hi, we are working on this problem, we will have a new version available this week
Posted: Fri Dec 09, 2011 12:39 pm
by l2net
there are problems when you play strobe work. The rate of bursts does not change linearly. The only problem is the screen itself the unit runs properly. thank you
Posted: Tue Dec 13, 2011 8:18 am
Does this happen when advanced rendering is disabled?
Check that the strobe property is set correctly in the fixture profile. You can set a minimum and maximum speed here and set linear or random.
Posted: Thu Apr 11, 2013 2:55 pm
by Thomasjueliversen
How do i create a fixture in the scanlibrary. Editor ?
I need to make a 7 Channel Par 64 Led.
Can anyone explain,
Best wishes
Thomas
Posted: Mon May 20, 2013 6:52 pm
