I'm triggering using hotkeys in SL2004. I'm trying to get the 2006 software
set up. When I set INIT on all my pages to the space bar it will work but when I close the program and open it again the INIT's on my pages no longer have "SP" in them. They work fine in sl2004 but not sl2006. I am also having a problem with the light beams in my scanners. the light wouldn't come on from my scenes until I copied "light beam on" to each scene. I copied everything from SL2004, which is working fine.
Hotkeys
Try this version: http://www.dmxsoft.com/beta/sun_2006.exe
Then, are you talking about the pre-programmed scenes ? If yes, they already have the "Lightbeam" ON or the profile is not correct.
same problem
I've had the same problem too, it doesn't seem to save the shortcuts on the INIT button! I just set up a new button called INIT2 or something like that!
