Hi, can anyone help? I have an IP DMX module and I have two versions of Sunlite installed in my machine - 2004 & 2006. The 2004 version had a patch in the ini file which allowed it to recognise the IP module. Can you tell me whether there is a patch required for the 2006 software? I have tried all of the various startup parameters with no luck. The 2004 version works fine and the presence of the DMY IP module in shown on the startup flash screen. The 2006 version does not recognise the module on startup. I wold very much like to start using the 2006 software but cannot do this until the unit is recognised.
Many thanks
Stuart Roberts
IP Interface with 2006
Jump to
- Software (English)
- ↳ ESA Pro 2.1
- ↳ ESA Pro 2.0 (Legacy)
- ↳ Easy Stand Alone 2
- ↳ ESA Pro
- DINA Hardware
- ↳ DINA DR1/SR1/DR1 Lite
- ↳ DINA DR2/DR2 Lite
- ↳ DINA - DR MICRO
- Arcolis Suite
- ↳ Arcolis Remote
- ↳ Remote Classic/Remote Pro
- ↳ Arcolis Designer
- ↳ NATOUCH-1
- STICK Hardware
- ↳ STICK-DE3
- ↳ STICK-CW4
- ↳ STICK-KE2
- ↳ STICK-GA2
- ↳ STICK-GU2
- SLESA/SIUDI Hardware (English)
- ↳ SLESA-U11
- ↳ SLESA-U10
- ↳ SLESA-U9
- Discontinued Hardware
- ↳ STICK-KU1/KE1
- ↳ SIUDI 8C - SIUDI 8A
- ↳ SIUDI 7A/7B
- ↳ SIUDI 6C - SIUDI 6A - SIUDI 6D
- ↳ SLESA-IP1
- Legacy forums - moved to sunlitepro.com
- ↳ Sunlite Suite 3
- ↳ Sunlite Suite 2
- ↳ Easy View 2006
- ↳ Easy Show
- ↳ Français
- ↳ Español
- ↳ Sunlite Suite
- ↳ Other Legacy Products
- ↳ SIUDI 5C - SIUDI 5A
- ↳ SIUDI 1B - SIUDI 2
