flash button.
flipje100
flash button.
Post by flipje100 »
hello,
If I want to control a flash button with a push button on my controller. How do i do that ?
I've used button activation, but then i have to push twice to activate and deactivate the button?
greezt flip
roberto
Post by roberto »
Go to "Button", "Settings", "Trigger" and there you select "Flash Mode".
The shorcut, is to hit the Control key and without releasing the Control key, hit the key you want to select twice.
flipje100
Post by flipje100 »
yes that I know,
but that works fine if You use the keyboard of a Laptop.
But I want to use a hardware controller, and program a button to acces an flash-button in sunlite.
the Button which i want to use has already the flash option.
greetz
roberto
Post by roberto »
If you have a Midi Controller, you can program it with the new Midi Console included on the SL2006
flipje100
Post by flipje100 »
That i've tried
but if i Push the contollerbutton, the flash-button goes on. I have to push again to get the flash button off!
Am i doing someting wrong?
greetz Flip
