i installed sunlite 2006 on my main pc and on my laptop and on my laptop it runs fine until i close the program then it crashes but that i dont mind as it runs fine for the shows i do.
My main problem is on my main pc every time i go to use it it crashes and will not respond i tried doing a clean install on the pc but just does the same every time i use it. Its sarting to be very annoying as a would like to set up for a performance on this pc as it is more poewrful and i should be able to get the best use from it bnbut i cant can anyone suggest anything that may help ????????????????????????????????????
Why does sunlite 2006 crash on my main pc but not my laptop ?????????????????
We found and fixed the problem in the next release.
You can download the latest version here : Sl2006.exe
------- Dylan --------
