hey people
how i can i use the chaser?
someone can help me?
regards
easytime thoughts
- Junior Forumor
easytime thoughts
- Sem título.jpg (57.76 KiB) Viewed 5687 times
Re: easytime thoughts
The little red dot in the window is the position of the "a" fixture for this curent step (1)
Create a new step (the button right above the big "step"), you will see a new line
added to the list window and the blue highlited will move to this line.
Now you can move the fixture to a new position for this new step (2) by :
1. right klicking the pointer on the red dot and draging it to a diferent position
(the previous step/position will turn to a blue dot), or
2. press the "a" on the keyboard and just move the mouse around the screen.
the red dot position will follow this movement.
The new position will be stored as where you last left it.
Create and edit as many steps you want, adjust the timing and be sure to enable the "loop" button.
Hope I was clear,
Hope I was clear,
