Addressing 4 Separate LED Pars Using the Fixture Group
Posted: Tue Jun 16, 2015 3:31 am
I have 4 LED pars on stage. I want to give each a different color and save the look as a scene. Yet even when i follow the instructions from the manual word for word im unable to do this using the fixtures group window. The moment i chose the second fixture and assign it a color, the first fixture also takes on the 2nd fixtures color.
I would like to add that this happens only when i use the RGB color mix button. My LED page also has a color switch with color presets and when setting with those, it works ok, but the downside is that i can only work with 6 basic colors then and cant choose subtle shades. Another workaround i found is that i have to create individual switches for the subtle shades i want and then do the fixture window select procedures and it works fine. Is this common, that you cannot do separate fixture color assigning thru the fixture window if using the RGB mix button ?
Can someone please help, its a little urgent and im desperate for some assistance.
Thanks in advance.
Thanks in advance.
