SL2048FC Turn it Of!!!
Roman82
Post by Roman82 »
SIUDI 5A - Firmware 1.36 - SN:293753153 PC.O
I hope you can help
An interface was put in OF!
When connecting to the PC interface are lit red yellow and green LED (Blinking).
When I open the Sunlite Suite 2006, automaticamante interface gets in OF, and sunlite suite does not recognize the interface.
I testie Tools.exe interface with and operate the TEST option, the interface is reset to PC and has DMX output signal.
But as soon as I close Tools.exe,the interface getting back on OF.
Please tell me in what way I can fix it.
Re: SL2048FC Turn it Of!!!
Try with the latest version and update to the latest firmware with tools.exe to see if you have the same problem
lotus2013
Post by lotus2013 »
Hi SimonB,
Did you managed to solve the problem??
I have the same problem. I hope someone can help us to answer the question.
I am using windows Vista 32 bit and the firmware version is 1.36
e-mail me your serial number and I'll make some tests
