Problem writting a show using Moving heads
Posted: Tue Jun 07, 2011 1:11 pm
by robcurrie
Hi
I need some help with a problem that i have with sunlite1. I am using it for a theatre show, and during a few scenes we use some PRXS250 moving heads, the programming is fine but after a scene with the heads they do a strange quick strobe and move to INIT position, this is regardless of whether I use fades and try to control the dimmer on the new scene after heads scene, and ideas anyone??
Re: Problem writting a show using Moving heads
Posted: Tue Jun 07, 2011 3:30 pm
by RichterMC
Hi Robcurrie,
can you give us some more details about your setup, please.
- Software version ?
- USB Interface + firmware version of interface ?
- what fixture profil are you using for the PRXS250 moving heads ?
Does the problem occur in "Easy View 3D" as well or just in the real world ?
I didnĀ“t understand this part, can you explain some more precisely, please.
Best Gernot
Posted: Tue Jun 07, 2011 8:12 pm
by robcurrie
Hi
Yes sure, Its Sunlite version 1. The USB interface is EC, firmware version - I will need to check (I think original firmware)
The profile is the PR XS250 standard mode from the Sunlite website.
The problem seems to be inbetween scene changes. If I have used the moving heads in say scene 4 in master page, I then move on to scene 5 but when I do this the heads strobe and then move to there start position (or INIT position - smae position when you turn them on). Its like they seem to be recieving some information for dimmer channel when they should have.
Posted: Wed Jun 08, 2011 6:56 pm
by RichterMC
Hi Robcurrie,
O.K. can you go to the "?" menu and choose "About..." , please.
On the appearing splash screen you will see a date, like "Dec 13 2010",
can you post this here please.
Windows Version ?
Is this reproducible everytime you change the scene or does it only occur intermittent ?
Best Gernot
