ERROR -> No synchronization 'Follows music pulses/BPM'
musicandmore
Post by musicandmore » Thu Mar 12, 2009 9:31 am
ERROR -> No synchronization 'Follows music pulses/Follows music BPM' in EASY STEP!!!
sunlite Suite (4.11.2008)
1) create a new scene (EASY STEP)
2) Sync to -> PLAY IN NORMAL MODE -> Everything OK
-> Synchronization with
Follows music pulses or
Follows music BPM in scene
(Audio analysis active-(BPM))
There is no synchronization between Steps and BPM or music pulses.
Are you so kind and give me help.
Thank you so much!!
LG,
musicandmore
bruno.falip
Re: ERROR -> No synchronization 'Follows music pulses/BPM'
Post by bruno.falip » Thu Mar 12, 2009 10:14 am
Make sure you start the "Audio analysis" tool and enable the audio input from the "Starting parameters" window.
musicandmore
Post by musicandmore » Thu Mar 12, 2009 11:45 am
Hi!
Thank's for the answer.
I did all the settings.
In 'Sound to Light' and 'Chaser' the function ist ok.
BUT in EASYSTEP the synchronisation doesn't work!!!!!!!!!!
When you have time please check this in your SW.
Thank you so much!
lg,
musicandmore
musicandmore
Post by musicandmore » Fri Mar 13, 2009 9:53 am
Dear Bruno
I did all the things. The problem (error) still exist!
If you have time, you can check this on your system please.
Info:
In 'Chaser' and 'Sound to light' modus everything ok!
I look forward to hearing from you.
(Please do not forget to publish this.)
LG,
musicandmore
musicandmore
Post by musicandmore » Tue Mar 17, 2009 3:16 pm
Dear All
Please, Please help me.
I need urgently your help.
I'm waiting for a ideal solution.
Thank you so much!
LG, musiclover
bruno.falip
Post by bruno.falip » Wed Mar 18, 2009 9:38 am
I have created a simple scene with easy step (3 steps) and when I select music triggering it works perfectly.
musicandmore
Post by musicandmore » Thu Mar 19, 2009 9:53 am
Hi, thank you for your answer.
I checked all the settings again. On my system there is no solution.
We checked this by my seller. The same problem!
Are you so kind and send me the show file (?*.ssh) to following email:
wesc1@gmx.at
Thank you so much!
LG.
musicandmore
Post by musicandmore » Mon Mar 23, 2009 8:24 am
Thank you so much for your scene.
I checked this -> I'm really surprised! The synchronization follows the music pulses!!
Why so?????
Please don't refuse my request. I will send to you my scene.
Are you so kind and check this on your system?
Thank you very much indeed!!!!
LG, musicandmore
musicandmore
Post by musicandmore » Wed Mar 25, 2009 10:19 am
Dear Bruno
Regrettably, I am unable to create a simple scene with e.g. 4 PAR 56 and trigger this scene with BPM.
Everything is ok (dim/intern sync) but synchronization with bpm doesn't work.
I send to you my scene. Apperent you had no time to check my scene.
I think without the cooperation of you, i can't solve the problem.
musicandmore
musicandmore
Post by musicandmore » Tue Apr 14, 2009 12:02 pm
Thank you for your Patch.
I will check your correction as soon as possible.
LG.
musicandmore
