master Flash....
Partycompagniet
master Flash....
Post by Partycompagniet » Sun Nov 14, 2010 8:17 pm
Can anybody please tell me if it will be possible to let an audio signal, for instance a beat from a drum, trig a master flash that overrides the show currently running, each time it appears ?
Best Regards
Re: master Flash....
Post by simonB » Thu Nov 25, 2010 10:37 am
Yes this is possible.
-Create a switch
-Select "sound to light" tab
-Select one of the blocks at the top..the one you probably one is the second to the left
-Select the channels which you want to apply the blocks to...eg dimmer channel
-The fader will split in 2, select the minimum and maximum values
-Close and save the button
-Open the audio analysis
-adjust the bass frequency range if necessary
-adjust the threshold until the FLASH light pulses correctly
-if you have no input, make sure it is enabled within the windows mixer
Partycompagniet
Post by Partycompagniet » Thu Nov 25, 2010 6:08 pm
Thanx a lot.. I got a master flash button that respond correct when i right click on it.. So far, so good.. But it doesn't respond to audio signal.. I have audio input from a synth drum, and audio analysis seems to work ok, and detects the signal, but the lights will not respond anyhow...
Regards
Ivan
Post by simonB » Fri Nov 26, 2010 9:24 am
If you go back into the button editor and go back to the audio tab. Check that the red lights are flashing.
If not, check that the rack is turned on (big red power button). Also adjust the thresholds in the audio analysis.
