Strange problem SL2000 and two interfaces (Still pause)
Re: Strange problem SL2000 and two interfaces (Still pause)
Post by simonB » Fri Oct 15, 2010 10:04 am
Does the interface work and then crash, or does it not work at all?
Are you using 32 or 64 bit?
Did the problem only start after upgrading suite1?
Select "?" and select "About". Do you see SL2048 written on the splash screen?
Does the problem happen when using 1 interface at a time?
