problem with audio analysis in sunlite 2048FC
winway
Post by winway » Thu Sep 02, 2010 6:16 am
We are using INTEL motherboard DH55PJ and are unable to use audio analysis. Pls suggest how to proceed.
regards
Rajendra
The following are two conditions:
1. In sunlite software Audio is enabled.
In windows sound setting:
all are ON nothing is mute or disabled.
volume is full.
Master volume of audio i/p is mute all
in above setting no audio signal appears at audio analysis.
2.when audio i/p for line volume, mic volume & stereo mix are turned on with recording volume at 10%, Noise appears in audio analysis and o/p sound have no effect on audio analysis.
pls suggest what modification it needs.
Re: problem with audio analysis in sunlite 2048FC
Post by simonB » Thu Sep 02, 2010 9:04 am
What exactly is the problem? No incoming audio signal? If so, check that audio is enabled within the starting parameters and check your windows sound mixer that the line in is not muted, disabled or turned down
