bug with " INVERT X "
Posted: Wed Feb 11, 2009 3:34 pm
i there.. i have a big problem with the x-y impostation...
in "page-setting" when i try to set the x-y amplitude and when i try to INVERT x or y.. the program don't save ALL the setting but sometimes lost the parameter of 1 or 2 projector...
if you want to see the example watch here... http://www.youtube.com/watch?v=-PsdFS_jJF4
(my english isn't so good ;-) )
in the video you can see 4 moving heads..
1step: i want to reduce the x moviment of all 4 mh ... and IT'S ALL OK!!!! (from 0.00 till 4.30 minutes)
2step: i want to invert the x moviment of 3rd and 4th mh... BUT when i click ok in PAGE SETTING the last mh lost the impostation and change it of 90 degree.. (from 4.30 till end minutes)
i have try that procedure many times and the mh that lost signal is not always the same or the last i select, but it's random select by program.. and it's not a problem of 1 mh but some times 2 or every mh i had invert the x...
i hope you understand the problem and correct asap.. thanks!!
