fade out i switchs
Wollsen
fade out i switchs
Post by Wollsen » Fri Jan 02, 2009 5:24 pm
Hi could it be possible to make a fadeout function with switchs, it could be helpfull if you want fade from on color to another one, ore when want to fade out when release a switch, this funtion where present in sunlite 2004 as i remember.
From denmark
Lars Wollsen
playboy
Re: fade out i switchs
Post by playboy » Sun Jan 04, 2009 8:01 pm
Switch can not fade - on/off more not
Wollsen
Post by Wollsen » Tue Jan 06, 2009 12:32 pm
that is not true if you made fadestep in the first step of easystep, then you go setting of the switch the you check "if checked the button do a fade with first step of easystep" with this you can get af fade in, but looking for af fade out.
