Color Manager
Jaume
Color Manager
Post by Jaume » Fri Apr 25, 2008 8:11 am
I have a COLORpalette of Chauvet
It has 8 modules of LED's but Color Manager only detects one module. I can't use 8 modules of that fixture?
If i use another single fixture. How can i configure position of each module?
regards,
Post by bruno.falip » Fri Apr 25, 2008 12:56 pm
You must use single RGB fixtures and setup a matrix.
Jaume
Post by Jaume » Fri Apr 25, 2008 1:38 pm
Thanks for your answer.
I test with a 12 single RGB:
1234
5678
I can configure in this position?
12345678
regards,
Post by bruno.falip » Mon Apr 28, 2008 8:18 am
You just need to select 12 RGB fixtures without any matrix, this is the default position.
Jaume
Post by Jaume » Wed Apr 30, 2008 3:05 pm
Thank you for your answer. Then I can't change position, only default position.
regards,
Post by bruno.falip » Mon May 05, 2008 7:20 am
Change positions where?
Jaume
Post by Jaume » Thu May 08, 2008 7:56 am
When i select 8 fixtures RGB appear like this:
But may be the real position are one to the other side for the next fixture. I can say to color manager this position?
regards,
Post by bruno.falip » Tue May 13, 2008 8:34 am
ok, now I understand. It is not possible to modify the position. Imagine a line with 50 devices...
