What is "Status" in Console?
luceses
Post by luceses » Wed Nov 21, 2007 5:40 am
I was wondering what is the purpose/function of the "Status" parameter when working with the BCF2000 Midi console? What should the levels be set to?
Thanks,
luceses
dylan
Post by dylan » Wed Nov 21, 2007 8:19 am
The BCF2000 can send 3 diff parameters :
- midi commande (like cc, midi note ....)
- midi channel
- midi status
you can modified this 3 param like you want in the BCF console setup, and after make a new midi learning in the sunlite console window.
------- Dylan --------
luceses
Post by luceses » Wed Nov 21, 2007 4:20 pm
Dylan,thanks for the reply. Yes,I understand about the parameters,but I DON"T understand what status is for. I do not yet own a BCF2000 so maybe I would understand if I did,but I have used midi for years and I have never seen a parameter called "status" and I do not understand it's purpose especially since it is a numeric value. For example,if it was "Status..On/Off" this would make sense to me,but a numeric status is unusual to me.So, I still don't understand what this is. Can anyone else try to explain.
Thanks,
luceses
