DMX Input to Control Sunlite
bjkered
Post by bjkered »
On the SL2048EC can you control the software using a DMX board or can you only control the software using a MIDI interface.
I want to use a very simple DMX board to control the software . I want to plug in the board to the 3 pin DMX input and assign faders to programed scenes and or Flash buttons on the board to select scenes or steps
Derek Barton
Post by bruno.falip »
DMX is possible
bjkered
Post by bjkered »
Thank you
If I look in the software where do you set the DMX to say a scene or step
Derek Barton
bjkered
Post by bjkered »
I have the software loaded and was wondering where do I go to set up a DMX input to an associatted Scene
for example if I have a scene of Par lamps on and want to assign a dmx input eg channel 5 on a DMX board to control the scene, where do I do this I slide fader 5 on the DMX board up and the scene is activated
Derek Barton
From the button settings window.
