Button are being invertet
Wollsen
Post by Wollsen » Fri Jun 29, 2007 6:00 pm
Hi...
I noticed at some time when I am Using midi keyboard and an keyboard at the same time, button gets invertet, then i have use the mouse to restore the butoon to normal fuction.
Any one have the same problem.
From denmark
Lars Wollsen
www.saxon.dk
Post by bruno.falip » Mon Jul 02, 2007 7:25 am
"get inverted"...what do you mean by that ? What is inverted ?
Wollsen
Post by Wollsen » Mon Jul 02, 2007 10:13 am
What i mean is that i have some button i flash mode, controlled by the midi keyboad, when i activate the button, with the midi keyboard the flash button is activated as it sould, but when i some times activate a second button using the notebook keyboard at the same time, the flash button get invertet so that you have to push midi keyboad to deactivate the the flash button, and when i release the midi keyboard the flash button becomes Active.
Push = off
Relase = on
playboy
Post by playboy » Mon Jul 02, 2007 10:21 am
Thats normal. When you switch on the Midi-Machine must all the switch-Button are off.When one is on and you start the Sunlight it is inverse.
