hello
i have to use a sunlite card.
its made on a pci adapter with db25 connector that contains :
rs232 port
dmx in
dmx out
ther is nothing indicated on the card.
the components names were tagged to dont see the name.
someone told me that it should work with sunlite 2000 software.
questions :
- how to know what model is ?
- is this kind of cards compatible with sunlite software 2006 ?
about my old sunlite version
i installed the das-ocx driver and restarted
on sunlite 2000 startup, the splash screen tells me :
sl600-nt4 founded on port com1
super
my baud rate is set to 32400 and it looks like working.
i will have to learn sunlite 2000 soft.
i keep the same question :
- is it possible to run this card under sunlite 2006 ?
super
thank you for answering.
my friend gave me a cd with "sunlite nt4" inside telling me that this is sunlite 2000.
so i used it to try.
then i have seen that there is a "sunlite 2000" version on your site, and i downloaded it.
it looks working, and has nothing to compare with sunlite nt4.
its really better, but i dont have any doc inside.
- do you provide a place to get a kind of "quick start guide" for sunlite 2000 or pdf manual ?
