Problem with Sunlite 2006 and Ethernet interface
Blackbird
Post by Blackbird »
I have a quite urgent problem: I do have a properly working setup with the EASY STAND ALONE Software connected with your new Ethernet interface. With that setup, I can also easily connect the computer (wireless) and chance whatever light I like to.
However, since the EASY STAND ALONE is not the ideal software to do live lightning control, I would like to chance to SUNLITE 2006. But with SUNLITE 2006 I cannot find the Ethernet device nor connect to it, even if I do not chance any network settings at all. Why that? What do I have to do in the SUNLITE 2006 Software to configurate it properly? In your manuals you are quite briefly on that subject.
Or does the Ethernet interface not work yet for the SUNLITE 2006?
Must I deinstall the EASY STAND ALONE first?
Do you have more specifice manuals on that subject?
Any other ideas?
I look forward to your answer. Thank you!
Guest
Post by Guest »
The SLESA-IP product will never be recognized by Sunlite 2006. It only works with Easy Stand Alone.
Blackbird
Post by Blackbird »
So there is no work-around, no new Ethernet interface, no nothing at all to get the Sunlite 2006 work properly over Ethernet?
Thank you for your help
